Mp3
momokoke
That looks pretty cool.
I have a friend who does all the stereo fitting stuff, so I'll go see him tomorrow, and see what else there is I can do - but I have to say, that is looking pretty good!
Neat solution! How did you manage to route the cable to there?
Thanks,
David.
i am also interested in what was involved in connecting it to the headunit. was it a big job ? (dash removal?)
i would be fitting mine into a 2005 T-Sport
Thanks,
David.
If I remember correctly these are the basic steps of how I did it - its hard to explain without pictures.... If I get time this weekend I guess I could write a proper guide up.
To route the wire to the ipod through the dash from the upper armrest section you have to:
1. Remove the two screws either side of the upper hinge, drill a hole where the wire will come out - and feed the wire though this hole.
2. Remove the two screws either side of the lower hinge and drill a hole so the cable can get through to the gap that goes into the centre console.
3. Feed this cable through up to where the main dash is - near the centre flip down compartment - I had to take the whole bottom centre console out to do this easily. I also taped the wire down so theres no chance of the wire getting tangled with the gearbox/handbrake!
Now you need to connect the wire from the ipod to the stereo - there was a guide somewhere on here to replace the stereo - I just followed this but instead of replacing the stereo I had to connect the other half of the ipod kit to the stereo (Like connecting a CD Changer) then connect the stereo end to the ipod end.
Then of course you just put everything back together.
I know this might sound like a complete nightmare to do but it wasn't in reality and took me less than an hour to complete.
* This is only a rough guide so please dont sue me if you wreck your car!
Hope this helps
John
damn and blast !!
i have the W58818 headunit.. but this is not listed as a compatible headunit !!!
damn and blast !!
Might be worth giving them a ring as mine wasn't listed till I asked them if it would work.
