Intercooler
CAMSHAFT
would anyone have a spare standard intercooler off a 185/205 that i could buy, need it for a little project of mine. anyhelp would be great.
robbie.
try the gt4 owners club also mate , lots on sale there.the 185 and 205 intercoolers are totally different by the way.
in what kinda way??? i.e size ect?
st185 is air intercooler , the st205 is a chargecooler with fmic .
checked it out its a chargecooler from a st250, can i have your one you will never miss it :lol:
against a yaris i wont :P
A good FMIC is as good and can be more effective than the stock ST205 Chargecooler.
It all depends what kind of power your expecting to run and depends on the engine and thermal efficiency expected. Rate of mass flow and boost, size of compressor etc.
any help?
any help?
FMIC??
fmic = front mount intercooler
tmic = top mount intercooler
thanks now i know what ya mean, but its fot the yaris and the cooler off a st205 will fit perfect and will not effect turbo lag, but if i fit a front mount because the turbo is at low pressure i`m afraid of losing power.
before
after
so as ye can see i think its a perfect solution, can any one help???? :help:
you will also need a chargecooler pump and the small fmic , and then there;s the electrics to think about.
yea i need the electric pump and the extra radiator for the chargecooler's water. the electics cant be that much of a prob,
i've got a spare 185 TMIC if the price is right ;)
thanks its the one from the 205 i`m after.
you could wire it simply so that the pump runs all the time the ignition is on (not the best), wire it to a switch so you can turn it on or off whenever you want, or wire in a temp sensor so that when the chargecooler reaches a certain temperature it starts the pump.
not all that hard if you have half a clue :thumbsup:
