Does Anyone Pull A Caravan With A Rav4
I have a Diesel Avensis and I am thinking of changing to a Rav 4 ( diesel) to pull a caravan gross weigth approx 1300kg. Are there any problems towing with a Rav. I tow at present with the Avensis but have had to get a small cravan due to the low towing weight - and I want a bigger caravan ?
Have you seen the new Rav4 sub section, look at the top of the 4x4 section.
I have an 04 registered XT4. According to the manual, the towing specs are as follows:
Engine________________Drawbar load_____Towing Capacity (On gradients up to 12%)
_______________________________________With Brake Without Brake
1ZZ-FE (1.8L Petrol)_______75Kg__________ 1000Kg________500Kg
1AZ-FE (2L Petrol)________75Kg___________1500Kg________640Kg
1CD-FTV (2L Diesel)________75Kg__________ 1500Kg________640Kg
Hope that is readable? Sorry had to use underscores to get the spacing correct as the forum reformats multiple spaces!
Hope that helps :)
  • Topics
  • Our picks
        • Like
        • Like
        • Thanks
        • Like
