Rav4/ Towing
I am considering buying a diesel Rav to pull my new caravan (1400kgs) ---- do the make good towing vehicles any comments or advice would be welcome
I have an 04 registered XT4. According to the manual, the towing specs are as follows:
Engine________________Drawbar load_____Towing Capacity (On gradients up to 12%)
_____________________________________With Brake_____ Without Brake
1ZZ-FE (1.8L Petrol)_______75Kg__________ 1000Kg________500Kg
1AZ-FE (2L Petrol)________75Kg___________1500Kg________640Kg
1CD-FTV (2L Diesel)________75Kg__________ 1500Kg________640Kg
Hope that is readable? Sorry had to use underscores to get the spacing correct as the forum reformats multiple spaces!
Thanks for the information - have you or anybody had any problems towing -- I have a diesel avensis (2003) and use it to pull a caravan with a max gross weight of 1100kgs - I was in France two weeks ago and the dual mass flywheel went - people have since told me that toyotas are not designed to tow and that the flywheel going is a common fault with diesel engines , especially when towing. I wanted to buy a slightly heavier caravan , and didnot want to change to another make of vehicle , so thought that a Rav4 would be ideal. ( I would be gratefull if any one has any info)
Derek7470
Sorry, never towed any thing my self so can't answer that one. I'm sure some one around here will have though :)
The flywheel is the same part number for the Rav and Avensis
We have replaced flywheels several times on Avensis and twice on Rav4
Approx 50,000 miles
Not sure if the 2.2 Rav when it comes will be any different
Its an issue but a rare one. And out of all of them, all the Avensis were Taxi's and on Rav was used as a driving school car !
I trust you do realise that with a RAV you can not open the back door when you are hitched up! :angry:
On following website you can calculate different cars with different caravans.
http://www.caravantrekker.nl/index.php
http://www.caravanclub.nl/trekauto/tavhj20...02.0%20D4-D.pdf
Hopefully this helpfull.
My experience is good. I tow a Dethleffs Camper 450 DB max 1200 KG
I normally drive at 100 km/h sometimes 110 km/h. I think more than 1200 kg is to much to drive smooth.
And there is always the TTE performance kit www.TTE.de
Oeps I forgot to write that I'm driving a RAV diesel.
The rav4 diesel version was top in its group on the Caravan Club best tow car 2003.
