Do Subaru Whels Fit Celica?
sid-uk
yep, my impreza wheels fit on my celica , i think they are the same offset,
try them, if they dont fit then get spacers, that wll help
:thumbsup:
PCD is the same. Celica offset should be 35-38mm. The Subaru is 50mm So you`ll need 15mm spacers and longer wheel bolts. :thumbsup:
My wheels came off my mates impreza, only using a 4mm spacer and same bolts.
Just means your wheels will be 8 mm closer to the centre line of the car. Narrowing your track by 16mm. Unless you got wider tyres of course... :unsure: Ah the permutations are endless. :lol:
I actually had a mate who put different wheels on his car.. No big deal. BUT.... The bolts were actually held in place by TWO and a half threads. Nutter. :eek:
