hi
all, i've Toyota Caldina ST215W 4WD A/T w/ 3S-GTE, i want to try it on a drag strip just for fun.
My friend told me that i should upgrade the A/T for this, replace the friction and install high stall torque converter. I found oneebay converter, but do somebody use it? can i drive on the streets?
somebody tried this????????
  • 3 months later...
hi
HI I OWN A 1997 GTT CALDINA 3SGTE MANUAL I WOULD SAY THAT THERE IS NO NEED TO UPGRADE YOUR TRANS IF YOUR ONLY PUTTING IT ON THE TRACK FOR FUN ASLONG AS YOU DON'T DO IT MORE THAN A COUPLE OF TIMES YOU SHOULD BE FINE ITS WHEN YOU GET INTO COMPETION THAT YOU WOULD NEED TO MOD YOUR CAR NO NEED FOR JUST A BIT OF FUN :D
  • 4 months later...
Hi, I have a Toyota Avensis the 1998 - 2002 model. It is basically what is known to the rest of the world as Toyota Caldina 1997-1999. they played us for fools here in the U.K and introduced it as an Avensis before bringing in the real Avensis. The only difference from the 97-98 Caldina is the VVTi engine.
Anyway, am looking for a sport racing kit like the one on the TRD Caldina on the TRD website. I can't find it anywhere in the net. Some please help me find one.
Thank you.
