Need Help
S13boy
Hi, I'm helping Ukazn to do up his ST165 GT4,
as said in one of his posts he tried to drain the oil from the sump but drained the gearbox oil, I had a look underneath and found out it was the front diff oil,
I've looked for the filler plug for the diff but couldn't find it, what i can see underneath is two plugs on the diff, one on the left housing and one on the right and two more plugs on the left which looks like its on the axle.
Does anyone know where the filler plug is for this diff is.
Cheers
AK
ill find out tommorow for you
Thanks Dawesy, I've got a Nissan 200SX myself and its so much easier to work on, I didn't realise the GT4's were that complex.
What uprated intercoolers do people go for in these, can you fit a front mount somewhere in front? does it have to be watercooled or can you go for air to air.
Cheers
S13boy
