St162 K&n
CarinaII
K&N filter panel to fit in the stock air box.
or short custom intake pipework and cone air filter.
my st162..
so which cone filter is it, cause there isnt one listed for the st162. is it a later one or did you have to modify it to fit?
also, would i be better off with a K&N panel filter in the origional box, or a cone? Presumable, the MAF sensor can acomodate for the extra flow with a cone therefore giving a better (if slight) improvement over a panel filter?
I think most people have come to the conclusion that a modified air box with panel filter is better than a cone (for performance) - a cone will probably make more noise.
I think on the gen6's the general advice is to get an aftermarket high flow panel filter, then bore a 3 inch hole in the bottom of the airbox and make another cold air feed, this then gives it 2 sources of air
Don't think anyone actually dyno'd it yet though!
Well, i can get a green element for 33.26, a K&N element for 38.61, pipercross 23.16, a jetex cone for 58.65.
Which do you recon the best bet is? I'd sooner get a cone, because it free's up a lot of space in the bay, and makes it look neater.
  • 7 months later...
K&N dont list a 57i induction kit for the st162 celica. does anybody have any sugestions?
thay do make a standerd air filter that makes a differance
