Debadging
Quick question.... what's the best way of removing the badges (small side ones by the indicator)? Don't want to leave any marks behind.... I'm sure one of you must have done this already....
I have read somewhere that the professionals use a thin nylon fishing line and that the carefully apply heat (hair dryer or similar) to the Badge in order to soften the adhesive before they use the fishing line.
I used a cloth and a fine screwdriver and alot of nerve.But thankfully no damage, parked the car in the sun for a while,which was the hardest thing as it dosent happen very often in N.I. (the sun that is). But what you will need is tar and bug remover,or something like that to take off the access glue.Hope this helps.
pull the badges off and remove the adhesive with AUTOLGYM BUG AND TAR REMOVER, i did that with the ones on the back, you can't tell the difference and i put a T.R.D one there instead. :D
