Can anyone tell me if a clutch off a 1992 G-Limited 2.0 N/A will fit my 1991 UK 2.0 GTi?
Cheers,
Steve
Cheers,
Steve
Yup :thumbsup:
So why does the clutch kit for an import cost £90 and £60 for a UK spec?
'cause they love charging extra for imports ..
It's the same as on the Celicas ..
Well I have just been overcharged again today!
Will the import clutch not be a bit higher rated or something?
why? its the same engine, same power, same clutch!
Doesnt the fact that J-Spec cars are mapped to run on 100 RON change anything?... even the quotes for import engine's are higher than the UK spec.
i doubt the RON would change anything. At times ive had to fill up on really crap grade fuel, and the cars run fine. Mechanically the models are identical :thumbsup:
It's the same block and the same clutch ..
When they bent you over and shafted you, did they charge you extra for the "import Vaseline" too? :lol:
I cant understand how they can sell the same clutch but at a £30 price difference, they must be different.
They Screwed you!
get a uk chassis number and quote this EVERY time you go to mr t and you will save £££££
all a big con to make you buy uk models
They Screwed you!
No need to be an !Removed! Mat.
If I own an Import and they quotre me two prices, I go with the import price.
The clutch didnt come from Toyota anyway.
The beter thing to go is get a UK MR2 chassis number, and a GT4 UK Chassis number (if it's a turbo) for the same year as yours and always quote that.
No but they do charge for the 5mm rubber ring which looks 10 a penny. Even thats £2! :arrgg-matey:
Thats worth it though fella. Increaased lubrication, and response time is also increased as a result... :yes:
haha
-Z
