hey everyone, I was just wondering if I bought a JDM Toyota Starlet EP82 Front Clip ( like the entire front of this car) if i would have everything needed to do the swap?
yes
Does anyone else know for sure, because i do not want to spend $2500 and have to buy a different wiring harness or ECU some **** like that. I would really like a few more replies please. thx.
you need custom mounts i think - but part from that you should be OK.
J
I think your right! but you need a EP82 not a EP91 as the ecu doesn't
T
I beleive there will be a certain amount of rewiring to be done, and possibly modified engine mounts.
I beleive rules have relaxed now in Canada and you could buy yourself a Starlet and have that as a driver, or buy a Sera and put the 4e-fte in that which is a much easier conversion
engine mount fabrication is unnecessary. the motor bolts straight up. if he has the whole front clip, the ECU and wiring harness should be included, so go for it. it's the only way you'll ever make the paseo "quick"
