Problem...
3005
my celica aint working...
first time i try to start her she starts but then she just stops, same happens the second time and then the third fourth she aint starting at all then when i wait a while then the same happens she starts and stops again etc...
i got a 18R-GEU engine from the begining of the -80's
i think its some kind of ignittion problem, could be the coil igniter, was thinking to buy a new one but i hope i can find one i didn't find any info on the i-net :eek:
but it would be nice to get som tip from ppl that knows more about toyota then me :)
have you tried pumping the throttle/acceraltor while your starting it up..
(dont flood it though)
Not had this problem on a toyota but had ages ago on a motor with an idle wire going to the carb. There was a poor connection and without it the idle selloniod (cant spell) would not operate, hence the car would only start and not run.
It could however be a miltitude of things so at least check you are getting a good supply of clean fuel and (which I assume you have done) then yep look at the electrics.
Sorry cant offer more help
yes i tried the R.P.M goes up but it stops anyway...
and 1 more strange thing is that the fuel pump is always runing :wacko:
It does sound like it could be fuel starvation, amongst other things.
You say the pump runs all the time, do you mean when you just turn the ignition on but don't try to start it? It should only run for a couple of seconds to prime the system, and again whilst the engine is cranked. If it fails to start the fuel pump should shut off again. If yours doesn't do this, then it might be a bit of a clue, but I can't think what it would suggest.
Some possible problems on the fuel system might be:
Stuck open FPR
Loss of manifold pressure reference to FPR
Blocked fuel filter
Blocked breather in fuel tank (take off the filler cap and see if you get a rush of air)
Fuel pump relay
Faulty fuel pump
I don't think there is a fuel pressure sensor anywhere in the system that would shut off the pump (unless there is one integral to the fuel pump).
