My Hilux Smokes
gibson banda
my toyota hilux is diesel and when i start it in morning it smokes alot ( whitish smoke)
and then when the engine is hot the smoke stops. What could be the problem? What can i do for the smoke to stop? Please HELP!!!!
Have you any loss of power?
Has it over heated resently?
Is it using water?
i dont want to worry you here mate but it sounds like it could be the onset of the classic 2.4 hilux head crack but i hope not.
The 2.4 is basicly bullet proof apart from the origainal clyinder head cracks and about 30% of them do this.
To test if its the head you can have a cylinder leak test done.
Doesn't white smoke indicate water in the engine?
I was under the impression that cars smoked a little bit of white smoke when cold anyways, and it cleared up once warm....
Has it just started doing it recently, or has it been doing this a while?
