Radio
rallymad
The radio in my girlfriends yaris stopped working lately the tape deck worked perfectly but no radio stations were picket up she said it just went quiet i got another yaris radio in a scrap yard but it did the exact same thing the guy in the scrap yard said people are often looking for them there is notting wrong with the wiring as i fitted another toyota radio i had at home has anybody else had the same problem????
cant say i have
checked the aerial? not damaged, or hasnt let water run into the car through it has it, sounds silly but few people found this to be an entry point when raining it it wasnt on properly
apart from that i cant think of anything im afriad
maybe time for an aftermarket uni! :D :P
Mine had a similar problem when i bought mine, the tape and am radio worked fine, but the FM tuner was just crackly, Mr T took the radio out, sent it off and put it back in and now it works!
If the car is still under warenty Mr T will help!
Tell you what, your situation sounds similar to mine. My radio stopped working suddenly about a month ago. It can pick up the FM stations but I get high noise to signal ratio. It can only tune to AM stations, though and the Tape works fine.
I have had it since 1999 although I understand that they are supposed to last the life of the car. I know I can not complain ... Can any one help WHERE CAN I BUY A SIMILAR RADIO LIKE THE ONE USED ON A YARIS. My Toyota dealer does no do radio spare. SOS
winstoneg, Bolton, UK.
:angry:
or ebay mate. I know knightrider has one for sale at the mo
Thanks, Ross.
I 'd checked that one out, last night though. The bid then, was at 150 pounds.
My dealer says a new radio unit costs around 600 pounds.
And of course, if I decided to send it away to Bradford (3rd party repairs centre , I believe) I 'd incurr an initial charge of 55 pounds for carriage. Whether I decide to send it there or Toyota do it for me !
I know that there may be a middle way, somehow.
Thanks for all the help.
Thanks, Ross.
£600?? Would be cheaper to get a after market head unit AND it would be much better
Thanks, Ross.
Has anyone looked into WHY these radio sets, have just started to fail ... NOW. Is it anyything to do with manufacture batch (component wise) or is it a software bug. Has Toyota issue a service bulletine or alert to this effect.
Any possible sources from around the Northwest, for these 'after market units'?
