Coolant Type?
bfckarlos
Hi there,
I was wondering if anyone has any idea what type of coolant I should put in my '99 2.0L.
I want to flush out and refill but don't know which to use.
Thanks in advance. :D
Your better off sticking to the Toyota "Forlife" Coolant - it's ready mixed and once you have drained the old coolant and flushed the system through,just refill with Forlife. It prevents internal corrosion and turns yellow when it "detects" acidity in the system( eg head gasket failure).
:thumbsup:
                                                    :thumbsup:
Thanks Mick, that's just the info I needed. :thumbsup::thumbsup:
Does this coolant work for TD engines also? I've heard about the Toyota coolant already, just wondering if this is the right stuff to get! Cheers.
