Another quick job done
Rear washer not working Old shape Rav
Pop out the 2 push studs around the shocker mounting, catch the pins that u knock through
Remove the 3 x 10 mm bolts down the side of the wheelarch liner at the door side of the liner
Undo the 3 phillips screws around the inside of the wing & the one under the bumper
Give the liner a good tug to slide out
Found a 2" long pipe disconnected near the bottle fill up cap
Reconnect & rebuild
Job Done 20 mins
  • Topics
  • Our picks
        • Like
        • Like
        • Thanks
        • Like
