Footwell Lighting!
chrisb
Link for footwell lighting and possibly boot lighting!
http://216.239.39.104/translate_c?hl=en&u=...en/fu%25DFraum/
Just found after ive replaced all the interior panels of the car after routing ICE cabling!
Can anyone tell me whether ther is a limit to the amout of additional bulbs you could safely add onto the the dome light if any??
Thanks !
CB :thumbsup:
couldnt say, but i once wiered in 2 neons and had them running for a while, they only came on when i opened the doors tho
i then moved onto wiring them into a multi switch which was connected to the Battery, but all taken out now!
i had 4 blubs (cathodes (much brighter)) pluged directly into the Battery with a switch and it w0rked ace0... proper chav like tho
Can anyone translate? I can only ask "where is the train station?" in German.
(and no "i know a little german........ he's over there!!!)
Wahay
kind of translated so the majority can be pieced together...
i don't understand how he's wired it though.. It looks like they are on all the time, or only when he opens the doors?....
i'd been considering wiring two to the Battery, but using the ignition power to act as a switch... Was afraid of previsuly made chav references though...
i dont get the wiring either
the way i did was to just push into the white plug into relivant hole, but the neons only worked when doors opened
so i wierd up to Battery instead
so i wierd up to battery instead
Do u still have the neons in your car?
