45000 Mile Service
albi969
Hello All,
Straight to the point with this question,
Can anyone tell me what the main points of the Toyota 45000 mile service, are, what should be renewed , changed etc, ?, relating to the 98 Corolla 1.6 lift back Gs
Cheers Albi
Oil and Filter
Spark plugs
Air filter
Pollen/air con filter if fitted
Brake fluid check and change if required
Remove rear brake drums Clean out and check rear pads
General Lubricating of all hinges etc
Replace gearbox oil (not everywhere does this but is recomended at every 25,000 miles)
'Forlife'/Anti freeze check and replace if necessary.
Depending on where you go it could cost anything up to £230 at a reputable non-franchise garage.
Also when was your cambelt changed? - This may cost anything upto £90 ( including belt) if using genuine belt
Oil and Filter
Spark plugs
Air filter
Hey mate i am running a Toyota ceres/marino into which i have dropped a 4AGE Carina GT engine recently i removed the block off that and replaced it with 7 AFE block which is 1.8 ltr now the problem i am facing is that the cam belt or timing belt is too short i need 115 timing belt with rounded teeth any idea of any models that are running a timing belt of this nature
Tks
Oil and Filter
Spark plugs
Air filter
Thanks for the info gti ,cost me £180 for the service inc mot testt. coolant changed from blue to red !!!!.Work done at pentagon toyota rotherham . Quoted £165 for the cam belt change and will have done as soon as pocket allows, for peace of mind
albi969 Posted Yesterday, 04:54 PM
To have done what you did at a Main Franchise dealer is the lowest I have ever heard a main Toyota dealer charge... ...you have probabley found the best value Toyota dealer in the country :thumbsup:
