Fixed: T-sport Dash/radio Rattle
andyharding
I had a rattle/vibrating sound coming from behind the dash/radio when over 3K revs.
I finally tracked this down to the plastic clip that supports the A/C hose on the bulhead in the engine bay near the throttle cable. I undid the clip, wrapped some back tape around the pipe and then re-fastened the clip tight.
very intersting, will have a look myself. sounds like an easy fix.
mine vibrates a bit from behind the dash, but id just been ignoring it.
:thumbsup: bert
I think I have the exact same rattle. Does it go after 4000rpm then come back below?
I will look too cos its anoyed me for ages. Is this clip quite obvious to find because i am a bit of a novice under the bonnet.
Nick
Please tell me this is the same as the buzzing sound I have from behind the dashboard on the passenger side. It's been driving me mad and spoiling an otherwise perfect car. It's an '04 face-lifted 1.6 TSpirit. But the sound comes from inside the car, whereas your solution lies in the engine compartment?
