What Will Fit
Otto
What will fit my Yaris Verso?
I got the 14" 195.. is it 65? with te steel rims and plastic covers.
I just dont look that good. Nice wheels and tires makes all the differens.
I spoke to my Toyota dealer but i dont realy want tha standard rims.
If you got some wheels on that not everybody else have on the it tells the world that you care a bit tabout your ride. You got the interest..
But what will fit? 4x100 35-40ET yes thats a given but what dim?
14" is small.
15" I know will fit
16" I, hmmm will it fit?
17" no way.
I'm talking about a non lowerd Verso and no work done on the bodypanels oir springs.
How fat tires will fit? i dont realy know. 195 is standard. som 200-205 will probably fit without messing with the stearing.
Thats on a 6--6.5" wide wheel.
Whats your thoughts?
My bet is that I'll buy a 15" with a 200x55x15 tire. Not much exiting but a safebet.
Otto
You can get away with a 17" wheel if you have a low profile tire but you will still get a little rubbing. 16" wheels with a 45 profile is your best bet. Ask the boys at Envy to set you up. :thumbsup: Oh yeah and width wise you can easily use a 7" width no bother.
ok.. 1st of all you need to get wheels with a PDC 4X100 and an ET of 35 - 45 (all will fit) and no wider than 7J.
For tyres in....
15"- i would go for 195/50x15 (195/45x15 if lowering is planned)
Wheels for 15".. ET38 would be best
16" i would go for 195/45x16
Wheels for 16".. ET38 would be best
17" i would go for (and have) 205/40x17 (although if lower is planned, arch modifications WILL be required)
Wheels for 17".. ET42 would be best
There are quite a few variables.. so get proper advice from the retailer.. even better if the retailer is a specialist in Jap cars (Envy would be a good choice)
Davy
