hi i am trying to figure out what is wrong with my car. The problem is that after running for a while, the car stumble off idel. Which mean that when i am in a stop light and the light turn green and i get on the throttle the car idle dips down or some time dies then revs up. please help. I already change my spark plugs, distrubutor cap, ignition rotor. any clue. I was also wounder where the ignition coil is located because i am going to change that next.
Sounds to me more like ECU coolant temp sensor. Thats the one that sends the signal to your ECU to tell it what temp the engine is running at, not the one that gives the reading on your gauge :thumbsup:
do you know where that sensor is located at. i might take a look at it. in addition do you know where the ignition coil is loacted at want to change it. its still stock. thanks for the feed back.
i forgot to tell u guys that i have the US version. sorry about that
Not sure on the US version sorry, there was a PDF document somewhere with the parts breakdown of engine but can't remember where :unsure:
