Corolla Engine Not Idling When Cold
ninchn
I have a problem with my 1995 T. Corolla 1.3 Manual. Since a couple of days the car doesnt run stationairy any more when it is cold and stalls. After it warms up the engine runs fine. I took it to the mechanic, the injectors are cleaned, the sparkplugs checked, but the problem still persists.
According to the mechanic some expensive electronics need to be replaced in order to fix the problem. Is there any other solution possible?
Cheers
