My 89 Celica Gtr Turbo With A Splash Of Gas
bondango
ive had this car nearly 10 years so thought id show what can be done with a Celica
http://www.soundclick.com/pro/imagesBands/35696_36.jpg
http://www.soundclick.com/pro/imagesBands/35696_37.jpg
http://www.soundclick.com/pro/imagesBands/35696_38.jpg
http://www.soundclick.com/pro/imagesBands/35696_40.jpg
http://www.soundclick.com/pro/imagesBands/35696_41.jpg
http://www.soundclick.com/pro/imagesBands/35696_42.jpg
http://www.soundclick.com/pro/imagesBands/35696_43.jpg
http://www.soundclick.com/pro/imagesBands/35696_44.jpg
1989 Celica GTr
Fully Built Bottom end with Aries and Arp Hardware
3mm Cosmetic custom steel head gasket and Arp Studs
Full Ported polished Head and custom Valve Springs
Modified ACIS top plate
Custom Turbo manifold
T3/04E Turbo @ 8psi for now
Full Front mount intercooler and custom hardpipe kit+samco hosing
Custom oil and water lines
Custom Downpipe and exhaust
Greddy 720cc injectors x 2 intake mounted
Zex Dry shot 100bhp mounted before above
HKS bov
Blitz SUS Filter
Battery relocated to boot
Additional Pacet Fan with aircon removed
Camry v6 gearbox running late spec mr2 tubby LSD with custom gearing
Custom Built Clutch and uprated flywheel
Colour coded interior
Custom mounted oil/pressure/temp/boost gauges
A-pillar with Nos and AFR gauge
Custom White dials
Modified Grp-A shifter
Momo wheel knob pedals
Apexi SAFCII
Apexi AVCR
Apexi ITC
Greddy REBIC iv Injector controller
Lm1 Wideband
17" BK racing alloys
KYB Super streets + Intax Springs
Late spec UK GT4 Discs and Calipers
GT4 CS style custom bonnet
full onderground designs bodykit
Finished in BMW M3 blue
WOOF WOOF!
Welcome and a nice job on the conversion. :thumbsup:
Can I ask why you have used a camry v6 gearbox rather than the usual MR2 turbo one?
Stright swap, no %$(ing around with selectors, and matching halfshafts. Takes the power, and readily excepts other gear ratios from st202's and mr tubbys etc etc
and it was free from a low miler lol
Thanks, I think I'll go that route if I do a SC conversion then, rather than using the MR2 turbo box. I had assumed that they tubby gearbox would be a straight swap as well, but it sounds not. I will want an LSD as well though, so I guess I'll need a tubby one for that. Is it OK to use the standard camry box ratios, or are they too tall for the job?
Had them chaged to suit 0-100 times and not top end, but from what i can remember 3 4 5 are similar to the jspec gearbox ratios. If you go with a tubby box you will need inner shafts from the tubbyjoined to outers from early st185 and also front huns etc.
BUT, the st202 box takes an lsd from the tubby no probs, would be nice to see how strong the box itself is :bookworm:
The late ST202s in JDM form (known as the SS3 model), had a 200 bhp beams engine, and an LSD gearbox. There are pretty rare, especially over here, but would make a good choice of gearbox for a turbo conversion.
