Correct Tyre Pressure
Relm
I've recently purchased a GT4 ST205 and I want to check the tyre pressures but I can't find out what the correct pressures should the tyres are 225/50 R16. Thanks
Dunno if this is any help, but,
In my 5th gen there is a skicker in the glove box that states what the tyre pressure should be.
else i would go with 30 - 32 psi all round.
On my one there is a sticker on the inside of the drivers door. Probably the same on yours. Load of jap writing if you got an import. :lol::lol:
Correct tyre pressure for ST205 (UK spec) are:
Up to 130 mph: 34 psi (2.4bar) - all loads
Over 130 mph: 39 psi (2.7 bar) - Reduced loads (1 passenger)
46 psi (3.2 bar) - Up to full rated loads.
Compact Spare - 60 psi (4.2 bar)
Tyre size: 215/50R16 90W
Looks like you may have oversize tyres fitted.
:hokus-pokus:
Thanks jas147, I suspected as much! (Jap import not UK!) I'l have to pop into my local Toyota dealer and see if they can help.
:blink: hi
just a question ref the quote?????
were did these come from????
as i find it hard to belive that more pressure is required for the faster speed??because when i race my 88 celica i start the stage with 25psi in the tyres(on tarmac) and when i take presure readings at the end off the stage there upto 32-35 psi??
The pressures quoted are straight from the Celica Owner's handbook. :thumbsup:
