New Cold Air Box.
daktari
I wasn`t happy with the previous effort so i decided to utilise a bit of scrap stainless i had sat in the garage.
There will be a rubber sealing strip which fits around the top to stop any engine heat entering when the bonnets shut. :D
Have you got a cold air feed coming into that box?
Also, how have you bolted it into your car? You've got a piece of engine I haven't got!!
that's cos urs aint a gt4 :wacko:
:thumbsup: Interesting - It looks good
Thanks Gordy. :thumbsup:
It`s bolted by two small angle brackets, each end on the top edge and gravity and a tight fit does the rest. It`s pretty solid..
Two cold air feeds. One up between the inner and outer wing. There`s a 3 inch hole in the inner wing where the original resonator box was fitted And from behind the headlight. :thumbsup:
