Corolla 2003 Rear Speaker Install Question
saurus
Hello all,
I've just bought new rear Speakers for my 2003 corolla and i'm having problems getting the trim off to get to the Speakers. Behind the seats, there are plastic screws that turn but i can't seem to pull them off... anyone know how to get these mean suckers off???? is there some kind of trick?
TIA
cw
Hi
What do you mean about your can't get the trim off from the Speakers, do you mean around the speaker, or from the door trim itself??
Is you car a 3/5dr car??
When you say, there are plastic screws that just turn, explain??
I've taken off most parts of the door trim off (front & back), with very little problems
Hello all,
I've just bought new rear speakers for my 2003 corolla and i'm having problems getting the trim off to get to the speakers.  Behind the seats, there are plastic screws that turn but i can't seem to pull them off... anyone know how to get these mean suckers off????  is there some kind of trick?
TIA
cw
do you mean the plastic screws on either side of the bottom of the rear panels,if you do then yes you are right no matter how you turn you not gonna get anywhere,what you need to do is get a flat head screwdrive and pop it out.
they are not really screw's when you put the panel's back just simply push these plastic back in with your finger and believe it or not it does hold pretty good.
exactly!! Thank you, those suckers are tough!
