Sensor And Decatting, Warning Light?
zebidi
I disconnected the top sensor on the manifold for the cat. (pre-cat) it ran better then normal as it wasnt using it to calculate all the balls stuff that make it run economical.
If i fit the megan manifold that i got then there will be no mount for the sensor. has anyone else done this? How have you guys de-catted your cars? Please shed some light as i am looking to do this very soon. :help::help::help:
the sesor is there because the engine needs that information to calculate how much feul too use.
if u continue running the car this way, im sure it will cause damage too ur car.
if u have a hole drilled into the new part u want to fit, u can weld a stainless nut onto the pipe...thus u can use ur sensor again..
baz
If you can't find someone local to yourself send the Manifold up to me and I will weld a sensor boss onto the pipe for you.
HTH
Kevin
HTH
Kevin
For free? :P did buy it from you after all hehe
