what do I do with the oxigen sensor that is hooked onto the stoke air filer box when making a intake?
you need the sensor in the intake or else your ecu is going to get false reading, i know ppl riding without the sensor in the box but their engines do wierd things, so you drill a hole in the intake you're making, pull the rubber seal from the stock box put it in the new one, but some silicone lubricant on it(a bit not a lot!!) and away you go!!!!
I got the turbo off of a website, the turbo is made by ACTurbo, it doesn't seem to work right know, but I haven's installed my oxigen sensor yet, do u think this is the problem?
