Brake Bleeding
Can anyone tell me the bleed order on an MR2?
Also i have a rear brake sticking, was thinking of cleaning the caliper out?any other advice as i hear this is a common problem?
Cheers,
Steve
Try greasing the sliders on the caliper.. and the bleed order.. start from the furthest wheel from the master cylinder.. then next furthes.. then 2nd closest, finishing with the wheel closest to the master cylinder.
