Modding Help
Lia TOC
Right - my indicator is flasing at light speed, whilst the other one is going slowly(normal speed) WTF!!!!??? have a blow a fuse or something?
have you fitted the lights, sounds like a bad earth, if you have fitted the lights just check the connections
I think its a bust bulb - but how would i know where to check? Fuse box under the passenger side glove box thingi... but which one will i be looking for?
Not fitted lights yet but tried - can tell due to bust bulb!!!!
if its a bust bulb just turn them on to see which ones not working, it you have being messing round with the connections in the rear lamps check them aswell
Sounds like your indicators are on the blink :lol:
(It’s the bulb, put the hazards on and step out the car to see which on needs changing)
