Question
gramacar
Hi
Does anyone knows when exactly the miss-shifting problem
with celica TS has been solved? I would like to know the exact
date if it is possible and not an estimate. Is it a serious problem and
does the solution applies to all 2002 models of celica ts?
thanks
forget about mis-shifting problem plz, there were enough explanations in the last thread when you asked, most ppl who drive Celicas believe it is an driver error... I believe it was "solved" in April 2002, and those models have slower 0-60 times and harder gear change
Spwolf
Is it true that the celicas with the "fix" in the gearbox have
a gear lever with a slight incline to the right?
