Engine
Toyotariko65
Hi is it hard to put an induction kit on the gen 5 celica plz,
i have notice a type of switch on the air box and was wondering what that is for as i think i would have to remove it to fit the kit.
advice plz <_<
That's the air temp sensor (AIT).
You are probably better off with a replacement panel in the standard airbox, unless you find a kit that has sealed ducting right through to the front of the car (you might get a bit of ram effect from it).
