The Red Dragon
islade
Lets start about Red Dragon:
as I bought it month ago
inside
First I took all from inside
Then remove insulation from floor, beck etc.
To make it stronger many spots was spot-welded
!Removed! counting spots I counted wather drops from me..
Using expansion polyurethane foam in all frame structures, I so that !Removed! like to do this...
Cage in progress, pics tooken by mobile phone:
Rear tail lamps, like new, after polished with paper and polishe for LCD displays:
And new seats inc 3points racing harnes:
:thumbsup: Well done
..keep the pictures coming :yes: , very interesting.
Incidently with regard to the foam, I hope you never have to do welding in that area again...for surely you will set the car alight :eek:
continue with Red Dragon:
all side and central channal is filled with urethane foam
and cage is finished
your cage is made from exhaust pipe.those bends will colapse under load......lets hope you never roll the car.
good luck with the build though
do you actually drift this car...here is my drift car
actually you are half right, some 6 of us owners of AE86 in Croatia ordered one HEIGO cage and give it to local exhaust manifacturer to copy it. He have aluminised steal profile pipes and he just make it, so it is clear to see that he producing exhausts bytipe of cornering he made
if you can weld though, u could strengthen those bends with plates.
good looking car....
I allredy measured dimensions of trinagles to cut it down and melded in, just tommor I'm going on sea side so it will wait my ends of vacation.....
Allso I hava full room of parts to be put on like T3 camber plates, Coil over kit, springs 8 kg/mm, KYB AGX shoks, Roll Center Adjuster, strut bars, completly new
Red Top, small port, non TVIS, MAP, latest 4AGE produced for AE92 Swiss market and ECU to rebulid all and put in...
So till winter there is lot to do
tell me about it........ :thumbsup: ive lots still to do...it never stops.
  • 4 weeks later...
QA1 delirium coil overs front
QA1 8kg/cm front springs short
8kg/cm spring rear red
T3 chamber plates
Rol Center Adjuster
Toyo Team sticker
10mm silicon sparc plug vires and Iridium plugs
Late AE92 Red Top, small port, non T-VIS engine from ZaX
Engine rebulid gasket set, piston rings etc....
Synqron 10W-50 engine oil
High Performance 80W-90 gear oil
High Performance 85W-140 LSD oil
KYB AGX short stroke from SW20
painted inside, Ferrari Testarosa red
Two tone red/black panda style
Two new seats and racing harnes
Front Coil overs, inside AGX set on 25%, filled with Mobil1 S 10W-50 oil for cooling
very nice dude. proberly one of the best 86's ive seen :thumbsup:
looking very good buddy.
my car is currently totally strippd down to a Shell........
im doing a 400hp 3s-ge conversion over the winter using a GT2835R
the REBUILD topic starts from HERE.........
but i gotta say your 86 is looking good, when are we gonna see the pics of it in action :thumbsup:
tnx friends...
I practice allmost evrey moment I get free 4 it, bat I work 2 much so cars are only my passion for small free time...
for AE86 second engine will be soon finished, the racing one...
more soon...
for MR2 TRD2000GT project after allmost 1 year of seting we connected PerfectPower SMT7 ECU management and destroyed power amplifier of coil for sparc plugs, so I ordered new stronger one...
means 2 much job on cars 2 less time for practice of drift..
On next year we starts here localy drift competition, it will be good, here we hawe good drivers, I think some of them knows you from drift forums etc....
good luck with new engine...
my plain is when I finished this 2 beauties ( E12 I will not touch it will remain stopck car ) 2 buy Supra MKIV 3.0 TT and start to bulid monster....
  • 1 year later...
long time there was no update from me...
red top no tvis small port engine is inside
now brake lines, brake discs and pads
now lether on stering wheel
complete new exhaut system from 2-1, front silencer, ower diff line and rear silencer
and H4 Hi/Low HID 8k kelvin kit, work great
