Personal Light Problem.
gibsons
3 months ago I bought my company car for my partner. I wonder if anybody can help me as it's developed a problem on the inside cab light.
On negotiating a right hand bend, the interior light flashes on for the duration of the manoever. If the door locking button is switched on they also unlock when turning a right hand bend.
The car is 51 reg and has just completed 50 thou miles. Any advice/help would be appreciated as this is the first problem the vehicle has had since new.
Many thanx and best wishes from,
Gibsons.
Gibsons.
has it ever been in a smash
Thanks for he reply littlewener. No it hasn't been involved in any accident.
I have noticed it getting progressively worse though.
The slightest of right hand turns causes the interior light to flash on momentarily :help:
Best wishes from,
Gibsons.
Do you have an alarm with central locking interface?  :unsure:
Yes daktari I do. It's alarmed in four stages from the key.
Best wishes from,
Gibsons.
Righto. This is only a guess, It could be a short in the door switch circuit. Is there`s any way you can disable/disconnect the alarm and see if that improves things. Wiring faults are a right b***h to pin down sometimes. :yes:
