Electrical Problem
Got a little problem using the indicators or my tubby. when i indicate to turn right all is ok but when i signal left both sides flash (like using the hazard lights). i removed the flasher unit relay to have a look for corrosion on the terminals but it looks brand new. any ideas guys. ;) because it will prob cost a bomb down at the local auto electricians :!Removed!:
take all the bulbs out and check them too, if they have any rust on them, it will cause the shorting problem.
ok mate will do. thanks :thumbsup:
The wiring for the indicators goes through the hazard switch. It could be a faulty hazard switch. You can't easily check them unless you have a mate who will let you borrow his for a test.
Had the same problem on my old nova !
Indicators gor through the hazards as said !
My hazards switch was knakerd, and the lights always 'hazard' flashed instead of indicating.
replaced, and all sorted !
