Power Boost Valve
Andypr
<_< Has anyone on this site got a pbv fitted ,i'm sure i seen someone with it fitted,i've tryed all around but they do it for every other model apart from the yaris.
Many Thanks
you mean a boost valve as in a fuel pressure regulator?
if so FSE as good as they are will do the job, and the kits the do are normally a generic remote fitting that attached to the original fuel rail
but... do you really need one, your not gonna benefit unless the car has some mild engine tuning to start with
