Garage Quote
Buglc
Hi guys
Went and treated myself yesterday to a set of tte lowering springs! :D Got quoted £60 from my local garage (including balancing the front wheels) for them to be fitted.
Does this sound reasonable? :wacko:
Sounds pretty decent mate, I got charged £95 for my shocks and springs to be fitted and my wheels balanced! :thumbsup:
yea should take too long for any half decent garage, believe mine took an hour and half if i remember correctly
On eBay........
It says that the T-Sport and SR already have the lowering springs as standard?
Is this true or is this only for the standard TTE springs and you can go lower on others brands if you know what I mean?
Hi guys
thats good allthought make sure they do it right i paid about that, but the ubikers didnt do it right and left a suspension stut screw out!, so even though its cheap make sure its ok
Balancing 14 quid....
:eek::eek: 14 QUID FOR WHEEL BALANCING :eek::eek::eek:
Hope that was for all 4 wheels. if not.. rip off!!
Edit: or was that 14 cypriot quids?
I want to get mine done. Anyone know a good place in the south? cheers :thumbsup:
Thanks guys! :thumbsup: Should have them fitted pretty soon!
well i think its a bloddy rip off, fit them yourself. its not hard....................................and its FREE!
I would but i don't have spring compressors! Is it possible without them?
You'd never compress them enough to get the spring off the shock, not unless you or a mate are incredibly strong!!?
ah ha jus spring standard ones off or use rope, and the new ones will be shorter, so easyier
an the sr tte springs arent as low as the aftermarket tte springs
and spring fittings dead easy
well i think its a bloddy rip off, fit them yourself. its not hard....................................and its LEE
Damn right! :D
Springs compressors arent expensive are they?
All it is is threaded rod with some trianglar things on hehe
