Need Help To Find The Dome Light Wire
:help::help: Installing a aftermarket alarm and need help to find where the wire red/white (- ) for the dome light. Someone told me is under the steering or passager side kick panel. I spice the wire connect to the alarm ecu and none of them work. Please help. Thanks
If you cant find the light wire, im pretty sure you can connect it to one of the door pin wires...if the wires long enough.
Else, use a test light, connect it to earth, then put the other end into the fuses / back of the fuse wires one by one opening and closing the door..then you'll see which one comes on when the doors opened ! get me !
