St205 Diff Oil
Dax
i did the inside top cv boot on the passenger side but some of the oil came out when i took out the drive shaft. Im just a bit unsure where i fill it and check it from, does any body know cheers! :help:
there should be a fill plug, make sure car is on level standing and fill it until it runs out this fill hole.
where abouts is the filling hole tho, wot side is it on ha ha, im lost i dont wanna take out the wrong plug! <_<
there should be a drain hole at the bottom and a fill hole half way up the diff.i will go look at mine now , give me 2 minutes.i take it you mean the rear diff and not the front ?
i tried taking out an allan key plug on the passenger side just above the diff but it had a spring behind it so i left it alone!
sh*t no sorry i did mean the front, i didnt read that bit :wacko:
well the rear one appears in a small window in the sub frame/rear diff mount on the passenger side looking from the rear of the car , looks like a 12mm head with a 4mm thick plate washer behind it. Cant get at the front ones for now car is in the garage and john smith has called round. :D :thumbsup:
i will check my toyota epc for you - is it an import?
cheers mate ill check the back one any ways just for good measure, back to the drive way ha ha :thumbsup:
