Diesel Turbo. Will It Fit?
Luize
do they both have the same engine code? I mean as in "3S-GTE" or "1ND-TV"...
If so then I would say that it was worth a punt...
Depends what age of Hiace I guess... Do they not share a chassis?
Good luck,
Alan :thumbsup;
Good luck,
Alan :thumbsup;
im not sure, hiace is only 3 years old, looking at eBay thats off an older hilux, i dont know about the engine code, il have to look at it in a bit.
:thumbsup:
Also another thing to consider is you may have to change the manifolds because normally N/A manafolds differ from a manifold that has to accomadate a turbo and you also would have to find a way to pipe in a oil supply to the turbo.
The engine code for the 2.4 turbo diesel hi-lux surf is 2L-TE
HTH
Steve
So the code for your engine would be a 2L-T"something" ... I believe the "E" means its turbocharged.
Where are the engine geeks when you need them :rolleyes: I'm only repeating stuff I read here a while ago...
A
HTH
Steve
A
I would have thought it would be the T i could be wrong but the about this on the Hilux's but on the MR2 SW20's the N/A engine is the 3SGE and the turbo charged engine is the 3SGTE not sure if the same rule of thumb goes for all toyota's
Aaaahhhhh..... Could be...
I may have got that mixed up.
Sorry... :ph34r:
Alan
Ok ive found out what the last letters mean of the engine code mean for the hi-lux 2.4 2L-TE
the T means turbo
and
the E mean that the fuel system is electronic (basicly the ECU that the 2.4 td has)
