Injectors
zebidi
from memery, the injectors on our car has a different injector tip length so it may not be viable as a simple swap
they generally are a common fitting and they are all colour coded on the capacity, but as said above the tip, and needle can differ...
best talking to an expert on the matter
my cousin will give me his scooby P1 injectors if they fit, thats why I wanna know. 440 injectors!  :P
What do you hope to gain by fitting non standard injectors then?
What is wrong with your existing injectors?
true, unless youve got the need to force more fuel in, AND something to control them, and more than likely an uprated pump to maintain an adequate supply, its a bit pointless!
as rob says, absoloutely no point unless you doing the whole system.
i will uprate fuel pump, fuel rail, i cant seem to find an inlet manifold anywhere for the vitz, more fuel and i need more air.
i cant decide on Tomei cams, springs or turbo.
Al these performance related mods are going to make it pricey to insure :huh:
