Lean Burn Sensor
clsp1963
need help in locating a lean burn sensor for my 100,000 mile carina e, warning light came on 2 weeks ago. local toyota dealer quoted £380.00 to replace as car was built in japan. need help
www.justlamba.co.uk take a look here should save you a few quid they only use original gear but cheaper you'll have to phone them with the measurement between the bolts ie 45mm or 55mm all the best Leachy. :D :thumbsup:
