Hi guys..
I've just been on the phone to my local(ish) toyota....
i'm trying to get parts for my Cynos, but they said they probably couldn't help as the Chassis number isn't being recognised by theyre computers :ffs:
Anywho - i asked them if i gave them Part numbers could they cross referance them to s ee what else they fitted... nope they cant :rolleyes:
:help:
Anyway with help from Toyota-man on this forum, the part numbers i have are below
Oil filter - 90915-10003
Air filter - 17801-11050
Fuel filter - 23300-19395
Leads - 90919-21587
Spark Plugs - 90919-01184
Pads Toyota 04465-10040
Rotors :43512-16080
L/H caliper 47750-10111
R/H caliper 47730-10111
edit - just had a call from toyota again..
new disks - £60 eash.
new Callipers - £190 each
:censor: :help: :ffs: :ffs: :censor: :help:
Can someone with access to the parts catalogue please do a quick search to see if the parts are available from another model....
Ta
J
J- i can't help with the part numbers, but those brake prices are pretty steep. I've seen performance rotors on eBay on several occasions. You might check there, they could be cheaper! As for the calipers, i don't think i've seen them cheaper anywhere. sorry m8!
Take it this is front?
I think that dave @ starlet gt turbo . co.uk (remove the spaces) will be able to sort you out some discs but you might have to remove your old ones and measure them up first. Also i think the starlet calipers should fit ok i will have a pair for sale soon if your interested due to a brake upgrade.
Simon
Id personally never buy parts from a main dealer, always go to the local motor factors, get the almost identical parts for alot lot less!!!
Rich
Hi guys..
:help:
Leads - 90919-21587
Rotors :43512-16080
Ta
J
J,
Those rotors are about the same by the time I factor in shipping to you.
The pricing on the calipers though is dead cheap mate.
We have a list price ex Japan here of NZ$950 each !!!.
Cheers,
P. ;)
James, I'll see what I can do with those oe numbers tomorrow at work, they should x refer to some aftermarket parts that you'll be able to pick up at a factor :thumbsup:
Cheers buddy :thumbsup:
J
Right mate part numbers are as follows
Oil filter - 90915-10003 - mann + Hummel W68/1, Blueprint ADT32109
Air filter - 17801-11050 - Blueprint ADT32244, Fram CA5391, Coopers AG1328
Fuel filter - 23300-19395 - Blueprint ADT32323
Leads - 90919-21587 - No luck :(
Spark Plugs - 90919-01184 - Bosch FR7KCX, forgot NGK equivalent which I'd recommend
Pads Toyota 04465-10040 - Delphi Lockheed LP460, Mintex MDB1251
Rotors :43512-16080 - Delphi Lockheed BG3414, Blueprint ADT343136
L/H caliper 47750-10111 - No luck :(
R/H caliper 47730-10111 - No luck :(
Hope that helps but I'm wary of the part numbers for discs and pads as they X refer to Gen 2 Paseo ones <_< which you've already tried haven't you?
Anyway disc dimensions are:
254mm diameter
18mm thick
100mm inner pitch
55mm centre diameter
4 hole with two location holes
Any decent factor should either carry, or be able to X refer these number mate, if you need anything else just give me a shout :thumbsup:
You sir are a &#33;Removed&#33; genius.... I'll give x factors a shout tomorrow
big thanks mate. :thumbsup:
I've already tried the gen 2 disks - they're smaller by a LOT mate.
Those disk sizes are they for the Gen2 or Gen1???
J
No probs mate, those dimensions are for Gen 2 and are the same as what are on mine, however some companies list a smaller 238mm diameter disc :thumbsup:
Hmm - that might explain why i got the smaller disks........ :huh:
i'll try & whip my disk off at the weekend :thumbsup:
J
