1.6 Vvt-i E12 With K&n Panel Filter
Toyosupra[pt]
Just bought the k&n panel filter for my 1.6 vvt-i (2002) and all I can say is it seems quicker and powerful in low rpm.
Yesterday i tested the panel filter in e12 corolla 1.4 vvt-i (2005) and in low rpm is more quicker too .. but the sound was different from the 1.6, it seems he had a induction kit :wacko::lol: it is strange because the 1.4 and 1.6 have the same compoenents (i think) :blink:
so in other words would you recommend it?
is it worth it installing a proper cone filter or does the panel filter work just fine?
yes, i recommend it :thumbsup:
i put the panel filter instead of induction kit because of the garanty
Whats the Partnumber from the Panelfilter from K&N for the E12 1.6 VVTI :thumbsup:
and what thit it cost you ?
The Kn filter is this:
33-2252 Product Specifications
Product Style: Panel Air Filter
Height: 0.938 in (24 mm)
Outside Length: 11.375 in (289 mm)
Outside Width: 5.938 in (151 mm)
Filter Re-Oiling Amount: 0.83 oz (24 ml)
Weight: 0.8 lb (0.4 kg)
Product Box Length: 13.5 in (343 mm)
Product Box Width: 7.75 in (197 mm)
Product Box Height: 1.75 in (44 mm)
It cost 70€, but in holland i think that is more cheap :P (portuguese Vat is 21% :censor: )
and just to check if understood correctly did u say that with the panel filter on a 1.4vvt-i the sound changed similar to an induction kit?
regards performance and throttle response do u feel a difference?
the induction have a nice sound, but not equal to a panel filter. But the 1.4 vvt-i changed the sound a little more .. than 1.6
That 1.4 vvt-i is Made in Japan (chassi nº JTD...) , and my 1.6 vvt-i made in UK..i don't if this explains anything
