Air Conditioning
ripspeedtimmy
Hey guys.
A few days back it was rather a warm day so i thought i would turn the air conditioning on. No Luck. I went to press the air conditioning switch and nothing, nothing at all, i can hear the switch itself clicking but the little light on the switch does not illuminate. I have looked at the fuses in the fuse box but they are all intact? Any ideas ppl?
Hey guys.
THE PROBLEM THEAT YOU MENTION SOUNDS LIKE THE BULB IN THE SWITCH HAS BLOWN.
NEED TO PULL OFF THE FACIA PANEL OFF AND THEN DISCONECT THE AIR CON SWITCH SO THAT YOU CAN ACCESS THE LITTLE BULB.
IF THE AIR CON IS NOT BLOWING COLD AT ALL, YOU MAY NEED A AIR CON REGAS. ANY DEALER CAN DO THIS FOR YOU AT THE SAME TIME THEY WILL DO A LEAK CHECK.
:thumbsup:
