T Sport
ratus9
hi
everyone
Anyone have some idear why my t sport is loosing power in all gears you can tell mostly at 40+ it does not gain power quickly and seem to slighty sputter and the next time the power is back and every thing is ok .
its like driving a 600cc foots on the floor and no power....
only got till the 12th and the warrenty runs out... :crybaby:
thanks
ratus9
hi
everyone
thanks
ratus9
Don't know what the problem could be........but im sure somebody will be along later!
What I would do if I was you would be to call Mr T and get it booked in asap if your warrenty runs out soon!
Sounds a bit like plugs or similar ?
Also speaking to Camshaft the other day and he mentioned a similar issue to do with air/fuel supply getting confused on the ecu.
Have you tried the good old - Battery off - wait 10 minutes - Battery back on technique?
At least it would prove it isnt a sensor error or similar?
after trying what clarky suggests, take it toyota asap before the warrenty runs out like dave said
Jay
if you want to reset ecu best to pull fuse out instead of Battery. cos then it JUST resets the ecu not everything electrical. anf less hassle.
hi
i'll give the ecu a go later when i leave work as for the sparkplugs they where change at the last service 40k a few weeks ago
mind come to think of it it was a bit crap in the morning 6:30 and damp but seem to be ok in the afternoon when it was hot yesterday ?
i'll get the toolkit out and check the connectors on the sparkleads if i can...
just a thought hope its not the cat on the way out
oh its got the mot on friday 9th at toyota too
thanks
hi
well i tried and removed the two fuses and waited 5 mins and was still a bit crap then went out later in the car and seem to be ok
driving this morning it was a little slow then it was mostly normal then seemed faster than it every was
got to take it in on friday for a mot
thanks
