Leaking Air Con
elliliz
my air con leaks in the passenger foot well, i have had a look and it looks like the water is coming out of an overflow or a cap has been knocked off. help
Welcome to TOC elliliz!
I'm sure someone has had this problem recently - let me see if I can find the thread for you and hopefully the solution is on there!
yup
look under the dash on the passenger side, theres a small rubber hose that leaks the overflow, if someone catches it with there foot it pulls it out of the exit hole and then fills the car up
just poke it back through :yes:
