Check This Out!
zebidi
Nice, but how many horses would you get and is it worth it? ;)
Seems paying alot for not alot tbh. :yes:
well they are gonna be top quality piston heads. plus piston heads are £88 on themselves. for a little more (that kit) you get bearings, gasket and some other bits.
Go ahead then if you think its worth it and we will quite happily read your results! good luck to you but yeah seems like it would be better combined with some other mods! HINT:Whitoosh!
yes to knightrider. this was going to be a package i would purchase if i had turbo'd it. conrods aswell yes. but heads would be the main thing.
a mapper recently told me that its really the fuel sides of things that will knacker the engine up. even with the bolt on turbos emanage or f con mini, it is best to get the ecu remapped and everything adjusted accordingly.
i.e fuel pump, pressure regulator, injectors, and fuel rail.
thoes are some fundamental things to serious consider and go for if you want to up the boost.
other wise.............. BANG ur reactions will be like this:
BANG!!! :!Removed!: :eek: :o :unsure::angry: :ffs: :( :crybaby::crybaby:
yep hes right. you cant increase the amount of air going into an engine without increasing the fuel too.
even with little mods like induction and exhaust, idealy to get the most from them, the ecu should be remapped (not possible with std ecu IIRC)
I would seriously hope not.
Otherwise, they shouldn't be having their car turbo'ed... :(
yes, not enough research leads to major problems. no good.
people that dont research shouldnt get a turbo cos it will force more air into their heads lol
why what does a turbo do?
pumps more air into your head making you a bigger airhead lol
*kidding* :group-cuddles:
