Spark Plugs...
burfitt101
ive been told that my st185 import needs special plugs ie £15.50 EACH ones but ive also been told by others that i can use normal off the shelf ones like the NGK. thanks for any help
james
You can use normal copper cored ones if you don`t mind changing them VERY regularly.
The plugs you need are platinum tipped NGK BKR6EPS or Denso PK20RB
or Iridium tipped DENSO SVK20R-Z8
They should last 60K miles and you can get them for about a fiver each if you shop around. Try Partco/Unipart. :thumbsup:
Fantastic, thank you very much... :D
