New Manifold
IanGT
Hi guys, not haviing much luck at the moment crashed my car last weekend so its of the road now for a bit bent axel now it need a new manifold small hole in it sounds like a lorry, it came with a after market 1 just wonderin if anyone knows any websites which sell aftermarket manifolds for st202's SS2. thanks.
I've never heard of any aftermarket manifolds for the 3s-ge. The main reason for this is because the standard toyota one is pretty good, so improvements would by marginal. Try and find a stock one unless you need something special to match up with the rest of your exhaust.
Maybe you can get your's repaired? Got any pictures of the damage?
Theres 2 holes, there was a metal jasma Badge welded over this area of the manifold when i bought it, must of fallen off to cause these holes :ffs:
How would a garage go about repair this? would they just weld?
They're tiny holes mate. When you said you crashed, I thought you meant you'd wrecked the manifold somehow. That should easily be repairable by welding the holes up. Any competent welder should be able to fix it. :thumbsup:
Ah ok thanks mike, when i meant crashed i hit a kerb which has knackered 1 of my alloys and bent pretty much everythin on the front left side not gonna be a small bill :(
